I have plenty of GB space but for some reason my captures always stops half way through because it hits 3 GB. I am using a WinTV USB for capturing and it only captures in avi which is fine except the file sizes are huge and I don't like using filters because the quality of tapes I'm using is not the best and the compressors make the file look really pixilated. I want to use no codecs, but the file gets too big. Is there a way to make the capture not stop when it gets that big?
try changing you drive to NTFS instead of fat32, i bet that's your problem
Guns don't kill people, people kill people, guns just make it a lot easier. -
You need to find a capture program that will do segmented captures.
Try VirtualDub
No file larger than 4Gb can exist on your disk, and many programs
will have trouble with 2Gb.
If you want larger files you will have to change to Window 2000 or XP. -
Originally Posted by Bilal
You may not want to go throught all the trouble.
NTFS is a file system that supports very large files.
You would have to change your operating system
to get it because only Win2000 and XP support it.
Which is better quality capture- DVD recorder or Hauppauge WinTV USB stick?
By akalsha in forum Capturing and VCRReplies: 9Last Post: 6th Mar 2012, 18:57 -
Question about how antivirus stops autorun/exe on USB
By jimdagys in forum ComputerReplies: 5Last Post: 23rd Feb 2010, 17:19 -
Capture from Sony DRV530, stops after 3-10 seconds
By tepeco in forum Capturing and VCRReplies: 0Last Post: 12th Feb 2010, 15:42 -
Hauppauge WinTV 2Go capture card was Kworld DVD Maker USB 2.0
By Vampire74 in forum Capturing and VCRReplies: 4Last Post: 19th Jan 2008, 09:59 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 18:05
