Hello,
I am new at burning DVDs from my home videos. I captured using Ulead VideoStudio. I imported it into Showbiz to edit and saved it as a DVD file. Tried to burn it with Showbiz but it said that the destination does not have enough space. I looked at the MPG2 file and it was 4.04GB. I thought that the DVD disc can hold 4.7GB? What am I doing wrong? Is there something I'm not understanding?
Dew
Try another authoring tool, like TMPGenc DVD Author. Probably want Showbiz reconvert the audio to wav/pcm and then it will become bigger. It may be possible to change that but I haven't used it.
You could just edit and even author right in your VideoStudio program.
There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
I ran into the same problems using TMPGE and DVDit. I would get the file size to about 4.2-4.5G and then Nero wouldn't let me burn because the disc wasn't big enough??? Finally had to re-encode at a lower bitrate and put 2hrs 17min on the DVD, but it was only 3.5G and it looks like poo-poo.
Are you sure the media is empty? Is it one of those cheap media? I have problem with them, couldn't wirte to full capacity.Try better media
Best Option for exporting 3.5 hours of video for DVD
By buddyreid in forum MacReplies: 5Last Post: 22nd Sep 2009, 00:57 -
Putting a 7.6 GB video on a DVD
By cameraz in forum Newbie / General discussionsReplies: 20Last Post: 18th Jul 2009, 15:24 -
Hours of Music without Hours of Video Data in DVD Architect
By Guff22 in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2008, 22:23 -
6 hours of good quality video on dvd
By gameroftheuk in forum Authoring (DVD)Replies: 1Last Post: 30th Aug 2007, 02:59 -
Putting together amateur video on DVD
By Spring Rubber in forum Newbie / General discussionsReplies: 1Last Post: 24th May 2007, 15:12
