  1. hi there,
    i'm using WINDVR to capture, which gives me a huge MPEG file. Lets say that file was 4 hours long, what tool would i use to compress it to a smaller MPEG that can then be authored an burned. TMPGE?
    May 2003
    Pal Realm
    You may get this new thread locked by a mod. Maybe not, but is really a continuation on your other currently active thread.
    Why don't you just take a peek in TOOLs - click the drop-down box for CAPTURE.
    They are listed there in one place for you. :c)
    There's no place like 127.0.0.1
    The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
  3. hey Gees,
    you're right, i think if i work with the tools and the advice given in the other thread i should be good...thanks for your help.
