C'mon guys, I know someone out there knows more about this than I do.
I've got some SVCD .mpg files that play a full 45 minutes with Media Player, but MP only reports 10 minutes of video. If I try to encode them with TMPGenc, it only encodes 10 minutes. If I burn them with VCDEasy, I only get 10 minutes.
I know it's all in there, because it plays in MP. I just can't seem to get it out.
Is there a way to capture the Media Player output? I keep on seeing "frameserving" in other posts, but I haven't found an explanation yet of what this is. Any chance frameserving is my solution?
If I should be asking this in a different forum, please point me to it. Thanks for any answers, even conjecture and wild guesses.
Ken
Perhaps this helps
Try to use VideoLAN for playing the file. VideoLAN plays almost everything and you can save the displayed stream to a file. If you have bad data in your source video, you can try to skip with the slider over this point and save the rest of the stream. -
Then, you have not looked very hard. :c*I keep on seeing "frameserving" in other posts, but I haven't found an explanation yet of what this is.
https://www.videohelp.com/forum/userguides/87270.php
Try searches in TOOLS & GUIDES
Just about anything you need to know is right there for you. :c)
One thing that'll help. Don't use WMP to play these types of files. Get PowerDVD or WinDVD so you can see a more "true" view of what you've got.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Congratulations. Glad to hear it. :c)
can tsmuxer change h.264 mov to m2ts files without reencoding?
By Onceler2 in forum Video ConversionReplies: 2Last Post: 20th Mar 2012, 05:47 -
Cut HD files (h264/avc) without reencoding
By cd090580 in forum EditingReplies: 3Last Post: 25th Jun 2010, 19:37 -
is it possible to author a BR usig m2ts files without reencoding?
By Onceler2 in forum Authoring (Blu-ray)Replies: 6Last Post: 5th May 2010, 11:23 -
How can i creade a Dvd video from camera files w/o reencoding them?
By junglemike in forum Authoring (DVD)Replies: 6Last Post: 7th Apr 2009, 20:41 -
How to backup multiple AVCHD files to BD-format DVDr without reencoding
By jodal in forum Authoring (Blu-ray)Replies: 1Last Post: 10th Dec 2008, 16:45
