Do I have to "invert" every few frames or ... Will a strobe light capture properly on video?? I imagine it would be jerky...? Any simple genius methods???
Oh, I saw a pretty tedious explanation once. :c* It was where you make a vid (to overlay) same length as original but alternate with one black, one white frame, and then make one or the other not show through filters.
I tried it - as an experiment - and it was not worth all the work involved.
You might? be able to fake the look by overlaying a black frame (or series of frames) every so often in a repeating pattern.
Easiest way would be to find a vid editing prog that includes its own strobe filter, or others may know virtualdub filter or avisynth script ways to achieve it.
You don't say what editor you use.
Good luck. :c)There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
What is the best way to apply Prolimatech PK-1?
By Stealth3si in forum ComputerReplies: 5Last Post: 6th Apr 2012, 09:37 -
How to apply filters to video?
By kaona in forum Newbie / General discussionsReplies: 0Last Post: 13th Apr 2011, 13:59 -
Strobe importing VHS to Final Cut Pro
By Huntr777 in forum MacReplies: 0Last Post: 15th Apr 2009, 14:59 -
Video Strobe Effect
By Habby in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 24th Feb 2008, 14:59 -
Choppy "Strobe" results on Divx Converter
By kirklt in forum DVD RippingReplies: 0Last Post: 28th Jun 2007, 23:36
