Hi,
I have an Eye TV 1.3 DVR running on Mac OS X 10.2.8......
Having played around with the HQ and Standard VCD settings for recording quality I decided to see if it were possible to find a happy medium between the two. I tried recording the same peice of footage at HQ and Standard VCD, and then demuxed the HQ MPEG and compressed it using 3ivX (MPEG4) codec. The idea being that although this would loose some quality, it would be possible to use a sufficiently high MPEG4 bit rate to produce video of a quality higher than a straight standard VCD recording, but still saving on space. The results didn't seem to support this (well, the MPEG1 audio -> AAC audio @ 160kbps didn't suffer any real quality losses) with video detail turning out considerably worse than the same recording taken on Standard VCD quality. I was just wondering if anyone had any advice or knowledge on compressing the HQ video to produce good results (i.e. better than Standard VCD but at about the same bitrate)?
Cheers,
Phil.
Results 1 to 1 of 1
Pioneer DVR-550H-s: transferring video from laptop to DVR's Hard drive
By anandmahey in forum DVD & Blu-ray RecordersReplies: 3Last Post: 30th Aug 2012, 06:38 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 20:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26 -
MPEG1-->MPEG4 / Just a nominal question..
By Gew in forum Video ConversionReplies: 3Last Post: 22nd Mar 2009, 11:34 -
Getting DVDs to MPEG4-SP or MPEG4-AVC
By WoWchamp in forum DVD RippingReplies: 7Last Post: 31st Oct 2007, 00:47
