  1. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    I need to remove the audio from a clip of DV in Studio 8 and replace it with something else.
    I had a play around last night and couldn't see any option, is it possible?
    I think I can manage adding new audio, I just can't see how to remove the existing audio taken when the footage was recorded.
    Many thanks,
    Will
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
  2. Member rkr1958's Avatar
    Feb 2002
    Huntsville, AL, USA
    Can't you just zero out the volume on the audio track for the video and then add in the new audio to the "music" (secondary) audio track in DV8? Then render (save) to AVI? I done this very same thing using Studio DV7.
  3. Lost Will Hay's Avatar
    Oct 2002
    Everytime I tried I was removing the audio completely (rather than from one clip), just figured it though and it works.
    Thanks, and thanks to vcd guru who PM'ed me this morning.
    Will
