Good day. just wanted to know if it is possible to link 2 computers via usb connection(using usb cables) so I can be able to access data or share data between the 2 computers ( similar to crosslink cable via LAN )
tnx
You have to buy a special cable for USB, but its possible, and will work with all versions of windows that support USB. However, those special cables tend to be almost as much as buying two NIC cards and a crossover cable. So think about it before you buy one.
"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
Hi I use a belkin direct connect. I use this as i have a laptop and desktop which needs linking. http://catalog.belkin.com/IWCatProductPage.process?Merchant_Id=1&Product_Id=66005
When I bought mine I paid something like £50. Maybe a bit expensive compared to using nics and cross over cables but for a laptop a nic could cost as much as £50. Hope this helps. -
Also consider that FireWire is a supported networking device. I'm not sure how exactly it works since I've never tried but it's supposed to. If you've got FireWire on those PCs give that a try too. Even if only one has a FireWire card you can get a decent one for pretty cheap lately.
I have a USB cable with software on order. I paid $22.04 shipped. Will tell you how it works once I get it installed. I think it is cheaper than two NIC cards and cabling.
Hello. -
You tend to save a little money. NIC cards go for around $15 and a cable around $8. So for $38 you can get an ethernet network. It really depends on if you would like to spend the extra money for a future investment. The problem with USB is the expandability of the network is very limited. If you later got a third computer, you could not easily add it.Originally Posted by Tommyknocker"A beginning is the time for taking the most delicate care that the balances are correct."
Which hdtv's have a USB port, so you can plug in a flash drive or USB HDD?
By snafubaby in forum DVB / IPTVReplies: 8Last Post: 30th Nov 2010, 17:03 -
Question about deleting USB drivers to fix lack of USB notification
By jimdagys in forum ComputerReplies: 13Last Post: 15th May 2010, 11:24 -
Cinergy 400 USB & pcmcia»USB 2.0 difficulties
By AEN007 in forum Capturing and VCRReplies: 0Last Post: 4th Mar 2009, 02:21 -
Can a usb mass storage mp3 player and usb harddrive coexist in vista?
By yoda313 in forum Off topicReplies: 3Last Post: 5th Aug 2007, 19:23 -
Using 500GB usb drive as player on Standalone with USB
By OdubruS in forum DVD & Blu-ray PlayersReplies: 5Last Post: 26th Jul 2007, 06:36
