Hi,I currently use Tmpgenc or Mainconcept to Encode my Avi's to Pal format,Then Author using Tmpgenc DVD Author & burn using Nero or CloneDVD.However i am going abroad for a few months for work think it is region 3 that is used there & i have just over a month before i leave so would rather convert to multi region now & can take them with me.So can somebody please tell me how i can do this with the progs i listed above or do i need another one,Thanks for any help James..
As will CladDVD and DVDdecrypter, they contain a box with the option to check it region free or not.
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Any that you author yourself will be region-free. :c) You should be fine.
There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Actually it depends on the authoring application.Originally Posted by GeesWant my help? Ask here! (not via PM!)
Does that not create region-free from self-authored files?Originally Posted by JamesyBHOY
Info offered was based on info supplied. :c)There's no place like 127.0.0.1
Yep, tmpgenc dvd author makes region free dvds.
(I checked it, "Disc Regions are 1,2,3,4,5,6,7,8" with dvdinfopro )
But remember NTSC and PAL problems...most PAL players/TVs can play NTSC but many NTSC players/tvs can not play PAL. -
It looks like Region 3 would be Southeast Asia and East Asia (including Hong Kong) and NTSC.
Don't know if you'd consider it for just the month, but one site that sells Region 3 DVD movies recommends this player for PAL to NTSC.
http://www.hkflix.com/hardware/sampo_612n.asp
Does not mention any TV requirements.
Perhaps something similar would work for you while you're there. :c)There's no place like 127.0.0.1
Make LG HT904SA DVD Region Free
By squid101 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 18th Dec 2013, 06:01 -
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 17:12 -
Make a region-free DVD?
By rumplestiltskin in forum MacReplies: 3Last Post: 14th Oct 2010, 01:47 -
Klipsch CS-500, need to make region free / code free / zone free
By Trialsman in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Nov 2008, 14:16 -
how to make dvd-rom region free?
By ieh4f in forum ComputerReplies: 6Last Post: 29th Jun 2008, 15:24
