Anyone flashed this???
Results 1 to 14 of 14
is it gonna burn my 4x +R media @ 8X? That would damn sure be nice. Hopefully Sony will release a firmware update soon which will allow the 510a drives to burn +R 4x media @8x. Apparently the Sony lasers are powerful enough and capable to burn up to 8x.
I'll upgrade to 1.0d though....although I can't see any reason to...the 510a burns every piece of 4x media i've put in it @4x..and does so flawlessly. What a drive! :P -
I just upgraded...but noticed something odd. The Sony firmware utility..makes you reboot your PC before it flashes the drive...that's typical of all the Sony firmware upgrades....and it's smart to reboot prior anyway.
But the odd thing was when my PC rebooted the firmware utility was the only thing which loaded up. None of my desktop icons loaded....and although I hadn't seen a firmware upgrade do this prior...I figured that was normal too..so I simply flashed the drive anyway...and it completed successfully. It said drive updated successfully...
but i'm curious...has anybody else that upgraded the firmware noticed that when the PC restarts initially..the ONLY thing which loads is the firmware utitlity..and NOT the desktop icons or other start programs?
I'm guessing that was normal and all the start programs were temporarily disabled so that they couldn't conflict with the firmware upgrade..but if anyone else has tried to upgrade and noticed the same....plz advise. -
yes i flashed my burner with that firmware and when it rebooted that was the only thing that loaded.
ghoster wrote:
cool..thanksyes i flashed my burner with that firmware and when it rebooted that was the only thing that loaded. -
No I haven't...lol....but there is no doubt that Sony can and hopefully will release a firmware upgrade to be able to burn to +R @ 8X. Apparently the current lasers in all their burners can support the 8x write power.defense - have you tried burning any disk at 8x?-B
I only set my burning software to the "MAX" option and that's been 4-4.3x for all my 4x disks. If you selected 8x it would probably just downgrade to 4x anyway. -
How do you know this? Is it on Sony's website?Apparently the current lasers in all their burners can support the 8x write power.
So what is this firmware really use for? I thought it will allow you to write at 8x-BI only set my burning software to the "MAX" option and that's been 4-4.3x for all my 4x disks. If you selected 8x it would probably just downgrade to 4x anyway -
It was in a published article.How do you know this? Is it on Sony's website?
Firmware allows for a number of things..one of them is write strategy. Not sure why you'd think you'd be able to write @8x with this latest firmware...Sony never specified that.So what is this firmware really use for? I thought it will allow you to write at 8x-B -
cdrinfo
Sony develops new laser diode promising 16X DVD recording
Thursday, 28 August 2003
Sony announced that a new 650nm semiconductor laser diode is currently developed, allowing DVD recording speeds up to 16X. First samples of the new "SLD1236VL" series are planned to be available by December 2003, while mass production will start in June 2004.
According to the company, current laser diodes used for Sony DVD recorders are capable of 8X recordingYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
yeah i flashed it in XP had no problems, it now burns at 4x on shintaro dvd's i bought which are rebadged Princos but it really shits me the sony dru510a does not support overburning to cdr's NO BULL
i would crap my pants if sony released a firmware that will allow you to burn at 8x with the dru500a. that would be awesome.
I just flashed my Sony DRU-510A to 1.0d and Windows XP Home Edititon also only ran the Sony flash update software upon preliminary reboot.
It *would* be awesome if they released a firmware update that would allow the DRU(s) to burn at 8X.
But then, you'd have to wait a while for 8X media to become affordable, and then, after 8X media became more plentiful, you'd have to sort through the Princos, the LongTens, and the other crappy vendors of 8X media.
Hell, we haven't even yet gotten 4X DVD media to the point where you don't have to pay attention to what you're buying. I am not looking forward to going through the same process with 8X media.
/Sony DRU-190A problem
By Quadzilla in forum DVD & Blu-ray WritersReplies: 22Last Post: 7th May 2009, 15:10 -
Sony DRU 800A Problems burning??
By khronos000 in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2007, 18:40 -
Sony DRU-810A question...
By bamabluebird in forum DVD & Blu-ray WritersReplies: 4Last Post: 10th Jul 2007, 11:21 -
where to get original Sony DRu-820a DVD Firmware
By scustalow in forum DVD & Blu-ray WritersReplies: 1Last Post: 15th Jun 2007, 12:00 -
Sony DVD RW DRU-830A
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 09:41
