when i Start the TMPGEnc it takes a good 50-60 mins to finish which is a pretty long time. is that how long it usually takes? and at the very bottom where it say "Settings" it has "Super Video-CD NTSC (MPEG-2 480x480 29.97fps CBR 2520kbps, Layer-2 44100Hz 224kbps) that goof or bad?
Results 1 to 24 of 24
Source material? Resolution, length, codec? That sounds about right for a DVD to SVCD conversion in CBR. MY VBR encodes take ....oh...4-8 hours for a DVD source.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Originally Posted by tmac2085
2.) If you don't know what Super Video-CD NTSC blah blah blah means then you NEED to do more HOMEWORK by reading some more threads and/or guides.
You really should read some of the guides. This stuff isn't as simple as it may look 8)
- John "FulciLives" Coleman
P.S.
Another good website for video stuff would be DOOM9"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Originally Posted by tmac2085"Art is making something out of nothing and selling it." - Frank Zappa
when u people use tmpgenc...does anyone use this....DVD for NTSC (North America and Japan) (MPEG-2 720x480 29.97fps CQ 65, Layer-2 48000Hz 384kbps)
because i just got done burning the first one i was talking about the Super Video-CD NTSC (MPEG-2 480x480 29.97fps CBR 2520kbps, Layer-2 44100Hz 224kbps)
i'm doing this just to see if there will be a difference in video or sound quality.[/i] -
i guess a VCD...i just want it to watch on tv...the first one looked pretty good...should i stop this dvd one since i'm not burning it as a dvd?
but when u say am i burning a dvd...that means putting it on a dvd-r right? if so no i'm not, i'm just burning on a cd-r -
If you're creating a VCD then select a VCD template. Don't let Nero encode your file, the quality is not as good as TMPGEnc. Use Nero for burning only.
BTW, Are you using one of the excellent guides from the guides section? It doesn't sound like you are and it would probably help you quite a bit if you did."Art is making something out of nothing and selling it." - Frank Zappa -
Nero is probably re-encoding it because you have used one of the MPEG-2 templates (SVCD/DVD), and are then asking Nero to burn a VCD (MPEG-1).
In order for Nero to burn SVCD's, you need a MPEG-2/SVCD plugin - which is not free.
If you want a VCD at the end, use the VCD template in TMPGEnc.
That way Nero should not complain about the MPEG file you give it being non-compliant.
cheers,
mcdruid.
P.S. VCD will be lower quality than SVCD - just the nature of the beast.. but VCD can be done more-or-less with totally free software. This is not so much the case for SVCD. -
Thanks for letting me know bugster - I won't bother with the plugin next time I do a re-install.
tmac2085 - looks like you can go for SVCD if you've encoded it then.
I think what you need to do is close down the Nero wizard, then start a 'New' project, and select SVCD as the disc type (rather than just using the wizard to select VideoCD).
As always - please correct me if I'm wrong. :P
cheers,
mcdruid. -
Nero should not prompt you to re-encode the file if you've done it right.
cheers,
mcdruid.
P.S. A lot of people prefer VCDEasy to Nero for authoring (and maybe burning) (S)VCD's - but Nero is probably more straightforward for your first few attemps. -
Originally Posted by FOOWant my help? Ask here! (not via PM!)
FAQs: Best Blank Discs Best TBCs Best VCRs for capture Restore VHS -
Mr. Smurf, I think you are developing a sarcastic attitude.
It's contageous you know. -
And you're surprised when Nero can't burn it all onto one CD?
I'm not sure if I understand the problem here.
If you want really good quality (i.e. better than VCD), but you don't want to have to split movies across several discs, I suggest you look into buying a DVD-burner.
cheers,
mcdruid. -
I've blown about 20 discs this month and have missed a few episodes because of power, bad timers, and VCRs that eat instead of record.Want my help? Ask here! (not via PM!)
Quick Question
By TagFan in forum DVB / IPTVReplies: 3Last Post: 26th Sep 2011, 09:45 -
Help needed asap. Question about older TV and Blue Ray Players
By ccff22290 in forum Video Streaming DownloadingReplies: 3Last Post: 5th Jul 2011, 11:42 -
TMPGEnc 3 - Quick Menu Question
By heyjjjaded in forum Authoring (DVD)Replies: 1Last Post: 17th Aug 2008, 14:05 -
TMPGEnc DVD Author 3 - Quick Question on a Setting
By heyjjjaded in forum Authoring (DVD)Replies: 4Last Post: 5th May 2008, 16:04 -
TMPGEnc DVD Author - Quick Slideshow Question
By heyjjjaded in forum Authoring (DVD)Replies: 2Last Post: 4th Mar 2008, 06:13
