Hello,
I recently formatted my hard disk, before I did, I had Videostudio 7 installed. Through my MiniDV camera I could capture from digital tv straight to DVD spec MPG2 with no problems, as long as the slider bar which plays off quality to speed was less than about 85%.
Since I formatted, I can only capture for about 30 seconds, until the frame buffer is full, even with quality/speed down to about 20%, then the capture automatically stops.
I was wondering if it could have been a codec I had installed before, or does Videostudio 7 use its own codec? If it isnt, then what might the problem be?
I have no idea what codecs I had installed before.
Rob
I do not think it is a codec problem. My frame buffer overloads in VS as well if I multitask.
Hello.
Problem with Ulead Videostudio SE DVD and EasyCAP
By Majora in forum Capturing and VCRReplies: 17Last Post: 20th Nov 2011, 04:51 -
CODEC problem
By DavidPriest in forum Newbie / General discussionsReplies: 2Last Post: 10th Jul 2011, 07:39 -
Sound problem with Ulead VideoStudio 11
By rogerhacker in forum Newbie / General discussionsReplies: 15Last Post: 16th Jul 2010, 20:41 -
Truncation problem when burning DVD using Ulead VideoStudio 8
By goodneit in forum Authoring (DVD)Replies: 3Last Post: 9th Jun 2007, 11:23 -
codec problem...
By cwb in forum EditingReplies: 6Last Post: 16th May 2007, 12:29
