Hi there,
I have a movie (avi) which is split up in parts that I want to join.
However, I have a problem : Every part's beginning repeats some of the previous part's last frames.
For example, the first two seconds of part 1 are the last two seconds of part 2 and the first two second of part 3 are the last two seconds of part 2 and as a result, when joining the files, the output is repeating those two seconds before going into the new part.
What I want to do is find which of the last frames of part 1 is identical to a frame from part 2, so as to cut out the first few seconds of part 2 and have a flawless joining.
How can I do that ? (I think VDub can't load two movies at a time to compare frames and find identical ones)
Thx in advance
go to http://www.iampornostar.com and get the JOINAVI program.
<font size=-1>[ This Message was edited by: gadget on 2001-10-08 17:12:05 ]</font> -
Hi
Load your part1.avi into Vdub, then select File > append vidio segment and select part2.avi do the same with your other avi's.
Now that you have them all as one, you can edit out the duplicates frames(cut at key frames)
joining avi
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Sep 2010, 07:13 -
Joining avi's
By Frisco656565 in forum Video ConversionReplies: 5Last Post: 9th Sep 2008, 21:29 -
joining avi clips
By natty in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2008, 12:32 -
joining avi's
By php111 in forum EditingReplies: 15Last Post: 5th Aug 2007, 10:05 -
Joining two AVI's???
By Kayfabian in forum EditingReplies: 1Last Post: 17th May 2007, 18:07
