Does anyone know if there is software available that can play back captured video at a variable rate? Something that would let you play back anywhere from half speed to double speed and a few setting in between?
Thanks for any help.
Results 1 to 1 of 1
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 12:53 -
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 10:26 -
Variable frame rate (vfr) and 120 (119.88) fps video playback big problem
By lovyagin in forum Software PlayingReplies: 0Last Post: 22nd May 2009, 04:40 -
Variable Frame Rate
By neoblood in forum Video ConversionReplies: 3Last Post: 20th Apr 2009, 15:50 -
What is a good software to encode variable bit rate MP3 files?
By jbitakis in forum AudioReplies: 5Last Post: 24th Jan 2009, 14:58
