I'm using s)vcd2dvdmpg v1.1.1.16608 and the svcd bin files are on my hard drive. The results are basically I'm getting the whole movie plus about half of it playing in the same frame. Any help.......much appreciated.
thanks
casba
Results 1 to 9 of 9
I'm using s)vcd2dvdmpg v1.1.1.16608 I don't see where those settings are....can you tell me how?
thanks
casba -
Check out the Pan & Scan samples: http://www.svcd2dvdmpg.com/SVCD2DVDMPG/Samples.aspx
This feature is only in SVCD2DVD v1.5 however.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Thanks ChrissyBoy.......still confusion on my part, I checked out the pan and scan sample. Would SVCD2DVD take care of this totaly or would I have to still ajust the standalone dvd player because its mentioned in that link that " For this to work you must set your player to 4:3 Pan & Scan before you play the DVD" (If my dvd player has that feature which I'm checking.)
If I burn the movie now that has the problem and ajust my standalone dvd player to 4:3 Pan & Scan (if it has that feature) will it work using s)vcd2dvdmpg v1.1.1.16608 and TMPGEncDVD author?
thank you
casba
Is the basic difference between s)vcd2dvdmpg v1.1.1.16608 and SVCD2DVD v1.5 is that SVCD2DVD v1.5 does the authoring as well?
thanks again
casba -
once pan & scan info is added to the mpg streams you still have to set your player to 4:3 Pan & Scan . Your player will have it as it is part of the dvd spec. The samples are the same as those which SVCD2DVD produces. Indeed they we created with SVCD2DVD.
differences are authoring (menus, chapters), pan & scan, auto sensing of source files, RIFF to mpeg conversion, large file support.... (off the top of my head)SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Once again thanks ChrissyBoy..... one last question....when loading bin files or mpg files into SVCD2DVD....SVCD2DVD would detect that this info is needed (auto sensing of source files)?
thanks
casba
I live in usa florida and have access to paypal what is the conversion needed for donation.....are you the creator of this program? I would like to get.
thanks again for all you help -
Most mpegs don't have pan & scan info. Currently, you tick a check box in SVCD2DVD to apply this info. SVCD2DVD will then add the info IF it is not there.
Autosensing is SVCD v's VCD or DVD compliant files over those files which need to be processed....
If this is your single reason for going to SVCD2DVD then i trust you have burnt the pan & scan samples & view them to satisfation.
Donation details are on the svcd2dvd.com site. See there re. exchange rates etc.
yep i am the authorSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Why do I have a red frame on my movie?
By DonCocof in forum Capturing and VCRReplies: 1Last Post: 18th Jan 2012, 02:18 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
POSSIBLE? Captured 8mm Movie Frame by Frame Editing
By PLW in forum Newbie / General discussionsReplies: 15Last Post: 21st Jan 2009, 13:21 -
Advancing/Rewinding Clip Frame by Frame on Windows Movie Maker (Vista)
By ione in forum EditingReplies: 20Last Post: 9th Sep 2008, 22:53 -
Frame jerking after converting movie to DVD
By lucontt in forum Video ConversionReplies: 10Last Post: 28th Jun 2007, 06:24
