Hi,
I used to be able to do a straight conversion from avi to DVD mpeg2 with Tmpgenc, choosing all the settings in the template profiles for NTSC DVD.
I would choose mpeg2 video with PCM audio, and Tmpgenc would encode both streams and automatically multiplex them and I'd have a finished file that I could burn in a DVD authoring program.
Now, with 2.59 Tmpgenc forces me to encode the two as separate streams and WILL NOT allow me to multiplex them together within the program. Anyone else having this problem? How can I fix it?
Thanks,
Justin
You should NOT multiplex:
m2v + wav -> MPG
m2v + ac3 -> MPG
MPG files are suppose to have mp2 audio only. Generally speaking most authoring programs what you to author from elementary streams. Are you sure that TMPGenc was multiplexing m2v + wav, and not encoded to mp2 audio in the past?
At any rate, I would jus author from the elementary streams. As an aside I would encode to ac3 to save space for future encodes.
Extract Audio and video from Multiplex karaoke DVD and re author
By quebecLA in forum Video ConversionReplies: 1Last Post: 8th Jul 2011, 22:01 -
MPEG2 Video with AC3 audio cannot convert to MP3 audio
By wenglock in forum ffmpegX general discussionReplies: 0Last Post: 7th Sep 2009, 21:52 -
Multiplex SD Mpeg with ac3 audio
By hartless in forum DVB / IPTVReplies: 8Last Post: 9th Sep 2008, 06:59 -
Mpeg-1 Audio Layer 2 - Audio Tag 50 - VirtualDub, TMPEGEnc Can't Read
By Rebooter in forum AudioReplies: 2Last Post: 26th Oct 2007, 21:51 -
Multiplex with two audio streams
By heretic754 in forum AudioReplies: 2Last Post: 1st Jun 2007, 23:44
