I followed the intrusctions set on the Converting and burning the VCD instructions but my VCD has turned out wrong.
I downloaded a divx .avi file and used TMPGEnc to convert it to .mpg format. When this was finished i burned it to a CD-R disc. Is this right? I have a Apex AD-600a DVD player which i know can play VCDs. When i inserted the VCD i had made, it loaded it, reconised it was a VCD. The problem is that i get sound, and the vcd is running but i have no picture. I checked the .mpg file before burning and then after i checked the cd on my pc and it worked fine. This was my first trial at a vcd so i am a newbie to vcd burning. If any one can help i would greatly apricieate it.
Thanks Tim
Results 1 to 1 of 1
Burning mixed/split mono VCDs
By ministry88 in forum Authoring (VCD/SVCD)Replies: 5Last Post: 21st Jul 2011, 13:04 -
Dl burning problems
By calanda in forum DVD RippingReplies: 13Last Post: 14th Apr 2010, 00:25 -
[Help] Problems creating VCDs.
By scott274 in forum Newbie / General discussionsReplies: 77Last Post: 15th Jul 2008, 03:43 -
problems burning iso
By hamilton accie in forum Authoring (DVD)Replies: 1Last Post: 26th Sep 2007, 17:41 -
DVD burning problems
By ssaamm in forum DVD & Blu-ray WritersReplies: 10Last Post: 22nd Sep 2007, 01:11
