  1. I captured two things with iuVCR and brought intended to load the first up, then "Append AVI Segment" to load the others in order.
    I have 4 clips total, and when I tried to load up the second one, VirtualDub gave me an error saying that the two frame rates were different.
    Any idea how to join them without screwing up the A/V synch?
    btw, the captures were 720x480 with huffy and uncompressed PCM audio at "CD quality." Thanks much
    Dec 2002
    This is common. IUVCR tries....but who says your source is exactly 29.97 fps? I would get 29.971 and 29.969 all the time. Tape was much worse than off-air.
    AVISynth won't join them either.
    Use the AVI Framerate app in the tools section to force the framerate to 29.97. VDUB/AVISynth will then append just fine.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
