I have a portion of video with scrolling text on the bottom that I want to remove using Vegas Video. I tried the Border effect but it adds a border to all four sides. How can I remove the text from the bottom only?
With Virtual Dub, you add a filter called null transform. It lets you add borders. If the file is MPEG, you can also use Virtual Dub, but it must be Virtual Dub mod, or you can use TMPGEnc, under Settings-->Advanced tab-->Clip frame.
Hello. -
Thanks. There must be a way to do this in Vegas though.
I figured out how to remove it using the pan/crop tool but that temporarily resizes the video which looks strange. The ideal way would be add a border on the bottom only. -
You did not mention you were using Vegas, and I had no way of knowing, sorry. The two ways told you about will crop from the bottom only. I hope you fix your problem, though.
Hello. -
Originally Posted by Tommyknocker
The title mentions you are thinking about using Vegas. I guess they teach hyphen usage differently these days.
Hello. -
How is it now? -
I found a solution here:
http://www.creativecow.net/index.php?forumid=24&postid=106561919520544
How can I have mpg with scrolling text?
By RBCC in forum Newbie / General discussionsReplies: 7Last Post: 25th Jan 2012, 04:48 -
Create scrolling text effect for Movie Credits using avisynth and png image
By wiseant in forum Newbie / General discussionsReplies: 6Last Post: 13th Sep 2010, 02:21 -
remove some text on avi video file
By SB4 in forum EditingReplies: 6Last Post: 30th Jan 2009, 06:30 -
removing scrolling text from videos
By planetx in forum EditingReplies: 5Last Post: 27th Dec 2007, 03:53 -
Scrolling Text - What's best authoring program for this task?
By crotchy in forum Authoring (DVD)Replies: 2Last Post: 5th Jun 2007, 19:33
