I'm having a really strange problem with AC3 audio.
I encode my audio using BeSweet (using 192Kbps 2.0) and author using DVD-lab. After authoring the DVD, I played it in my standalone player, and the audio was out of sync right from the start.
I played it in PowerDVD and WinDVD. In both programs, the audio is in sync, but when I fast forward, rewind, or change chapters, there's no audio at all. The only way I can hear the audio is when I play from the start and let it continue.
The strange thing is that I authored a DVD with AC3 audio last week using the same programs and it worked perfectly (the audio's in sync on the standalone and both PowerDVD and WinDVD, I can hear the audio after changing chapters or shuffling through the video).
I tried downloading the latest BeSweet files and put them in another directory. When I reauthor my DVD using the ac3 file that the newer BeSweet made, I play it in WinDVD and get no audio at all. When I play it in PowerDVD, the video plays really fast (and there's no audio).
Any ideas as to what could be causing this problem? I figure it's either BeSweet or the way DVD-lab is handling the AC3 files.
Results 1 to 1 of 1
Change video, keep audio without re-encode ? Problems with strange AC3.....
By Gwar in forum EditingReplies: 18Last Post: 27th Aug 2011, 08:19 -
mkv with ac3 audio -> avi with ac3 audio ? is this possible?
By Substance001 in forum Video ConversionReplies: 9Last Post: 20th Jun 2011, 23:56 -
FAVC re-encodes AC3 audio even when I check the "retain AC3" opti
By teapot in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2008, 00:10 -
audio conversion problems? (wav to ac3
By just in forum Newbie / General discussionsReplies: 9Last Post: 28th Oct 2008, 18:35 -
AC3 ACM Decompressor audio problems.
By cactusjack310 in forum AudioReplies: 2Last Post: 16th Dec 2007, 13:13
