Can a .VOB file be burned on a CD and play in a DVD player?
Are there any programs out there that will create and burn the DVD structure from an MPG2 file onto a CD? Is this possible?
dvd-video on cd/rw = minidvd or cdvd.
www.dvdrhelp.com/minidvd
(do a search for minidvd for more info) -
It's called MiniDVD and it doesn't work very often. Most players will only recognize the VOB structure from a DVD disk. A CD Disk triggers different hardware (SVCD/VCD) actions. Try it and see. You can usually only fit 20 minutes or less on a miniDVD. Even at 1/2 D1, you would have to use a pretty low bitrate to get a 1 hour TV show(48 minutes) on a disk. SVCD gives you much better compatability, for the same encoding effort.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
As an SVCD yes, just putting a VOB file on the disc probably won't cut it. The DVD player will expect certain things from a DVD. Since it uses a different laser, the disc probably won't be read.
I made a miniDVD the other day, just to see if it would work. It wouldn't play on anything (except a computer.) I have several DVD players around the house:
2 Panasonic
2 Apex
1 Initial portable (Walmart)
Most things I make (VCD, SVCD, DVD-video...etc) will play in at least some of the above. But the miniDVD wouldn't play in anything except a computer.
Newbie needs help with getting burned discs to play on dvd player.
By Takeonelastbreath in forum Authoring (DVD)Replies: 1Last Post: 22nd Sep 2010, 14:02 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 12:55 -
Burned dvd won't play in standalone player
By Shotobits in forum Authoring (DVD)Replies: 12Last Post: 13th May 2008, 01:21 -
converted vob files play on computer fine..skip when burned to dvd
By cduval04 in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2007, 18:26 -
xvid video I burned onto cd won't play in dvd player
By dvdnewbie64 in forum Newbie / General discussionsReplies: 11Last Post: 5th May 2007, 18:45
