Hey, I read about the header trick and I really want to try it cuz the quality on my vcd's kinda sux. I was just wondering if it would work on a portable VCD player (not dvd). Basically it's a player that can't play mpeg2, only mpeg. Would the header trick work for this or do you think it would just be rejected by the player?
Its unlikley to work, the data rate of a SVCD mpeg would probably be too high for a VCD player.
Only way to know 100% for sure though is try it
HAHA, no it does't work. It's a bunch of pink and green blocks. Whatever vcd is fine, but for some reason the vcd's flicker when I try to play them. Like when it's scrolling over a scene or when it switches from one veiw or another. Anyone know how I could keep this from happening? Would lowering the bitrate help?
Everything seems to be working fine now with regular vcd's. It was the FPS. The little vcd player can't convert 23.9 to 29 on the fly so it wasn't working with ntsc TV. w00t good thing i found that out. Now there's no need for header trick
Portable DVD Player vs Portable Video Player
By DJboutit in forum Newbie / General discussionsReplies: 9Last Post: 2nd Dec 2012, 18:28 -
Portable .FLV player
By Leppy99 in forum Portable VideoReplies: 0Last Post: 7th Dec 2010, 23:09 -
Portable DVD Player Help
By eastpole in forum Newbie / General discussionsReplies: 8Last Post: 14th Oct 2009, 12:39 -
What to look for when buying a portable player
By vcd_user in forum Portable VideoReplies: 2Last Post: 26th Aug 2008, 09:20 -
Portable MP4 player
By vcd_user in forum Portable VideoReplies: 39Last Post: 17th Jun 2008, 08:17
