DVD-video reallocation fail video might be unplayabal.
I get this sometimes, it happened to me with Dreamcatcher when I was ready to burn I get this screen I burned anyway but it was unplayabal on my DVD player How do I repair the files. thanks
I made a few coasters due to this.
It has something to do with a driver/hardware/media issue.... in other words could be anything..
The solution I found was to get the latest version of Nero, curently 6.0.0.19 and drastically use a clean installation of Windows (I have dual boot of XP so no big issue using Drive Image), try having a barebones OS install as 2nd, works wonders.
After this I have had no problems, I think it could be a possible driver conflict or software issue, because Nero was working fine until I installed more software on the OS.
In other words be careful what you install it could cause conflicts.
I dont know of a way to retrieve the data on the DVD, it tends to not be readable in a DVD-ROM drive also.
EDIT:
Sorry I was thinking of my other Nero favourite "Invalid block address...Could not perform end of Disc-at-once" and thereby wasting a disc.
Two ways to solve your problem..first find a reliable Nero version, again 6.0.0.19 seems to work well as does 6.0.0.11, but not 6.0.0.15!!
Use Ifo-edit to make sure all links are correct in the structure of the disc, i.e. that a link is not made to a file that doesnt exist.
Stick it though Nero when done and all should be fine.
You can read these discs in a DVD-ROM with DVD-Decrypter, do it in file mode, rip all files, use Ifo-edit, burn with Nero.
Problem should be solved.
DVD-lab burns DVD-Video, Ashampoo and ImgBurn fail... Why?
By nbarzgar in forum Authoring (DVD)Replies: 9Last Post: 1st May 2011, 14:27 -
Why does my Lite-On DVD burners fail on 8x DL discs?
By Onceler2 in forum MediaReplies: 26Last Post: 5th Jul 2009, 02:11 -
"DVD-Video files reallocation failed"
By alegator in forum Authoring (DVD)Replies: 3Last Post: 14th Dec 2008, 11:26 -
Why did I fail to use WinAVi to burn a DVD movie?
By efang622 in forum Authoring (DVD)Replies: 8Last Post: 29th Oct 2007, 13:12 -
DVD-video files reallocation failed
By Sean_ve99 in forum DVD RippingReplies: 3Last Post: 23rd May 2007, 19:44
