which is the best and simple tool to use for createing dvd chapter's?
Any of the consumer level authoring tools create chapters very easily. What exactly do you want to do?Originally Posted by WAK10
im just converting svcd and avi into dvd and i want to create the chapter's as well as what would be in a normal dvd.
If you're looking for a simple program trie TMPGEnc DVD Author. Well worth the money. http://www.pegasys-inc.com/
thank's!
is there a guide about how to make chapter's with dvd authour?
OOOOP'S found one!
thank's for the help!
Just had so many problems with tmpg author
after converting divx movies, always get some
header/GOP failure, byt Spruce-up seems to
get me through it...although tmpg author
does have better "chaptering" than spruce-up
i gotta go with whatever works right>>?
ifoedit can author, just not chapter dvd's
or just maybe i missed that guide...cheers
DVD Chapter Menus
By ssaamm in forum Newbie / General discussionsReplies: 4Last Post: 2nd Mar 2009, 12:56 -
DVD chapter not right how to fix it?
By warlock110 in forum Newbie / General discussionsReplies: 4Last Post: 19th Feb 2009, 21:36 -
New Website - DVD Chapter
By donaldallen in forum Latest Video NewsReplies: 17Last Post: 14th Jan 2009, 19:05 -
GUI for dvdauthor - How to make chapter thumbnails run the chapter video
By deco81 in forum Authoring (DVD)Replies: 4Last Post: 15th Dec 2008, 12:51 -
DVD chapter points
By Supreme2k in forum Off topicReplies: 3Last Post: 26th Oct 2007, 11:39
