hi
i was having problems capturing (detailed in this post https://www.videohelp.com/forum/viewtopic.php?t=179521) where i had been capturing fine, with no frame drops, then my 40gb IBM hard drive died, i bought a new WD 80gb 8mb cache hard drive and restored my system from an image, exact same settings and every 1/2 hour i would drop 3 frames.
i tried driver updates, different programs, and still had the problem. i got a replacement IBM 40gb hard drive and this hard drive had the same problem, while looking for problems etc on my computer i found an irq conflict, or "sharing" if you will, on IRQ18 between my Leadtek Winfast TV2000xp Deluxe capture card and my Realtek Network card.
this afternoon i did a clean install of xp, and have the very latest in all my drivers, also nvidia wdm 1.08 drivers, and applied the pci latecy patch. however the irq conflict still exists on IRQ18.
any ideas on how to change this, and also do you think that would be causeing the 3 frame drops every 1/2 hour?
Welcome to yet another M$ dark Secret.
In W2K and XP, IRQ steering is turned on by default. There is no way to undo it.
You can avoid it by setting some switches when you run the install program form a DOS prompt. This is the only time you can turn it off. The switch isn't there when you use the /? switch, it's not documented. Do a search on the M$ knowledge base under IRQ steering.To Be, Or, Not To Be, That, Is The Gazorgan Plan
Leadtek Winfast TV2000XP Expert problem with sound
By roc383 in forum Capturing and VCRReplies: 22Last Post: 1st Dec 2010, 12:32 -
Does the SpursEngine devices, IE Leadtek's WinFast PxVC1100 work good?
By TBoneit in forum Video ConversionReplies: 3Last Post: 15th Aug 2009, 17:50 -
Leadtek Winfast pvr2000 (retail)
By fulgur in forum Capturing and VCRReplies: 7Last Post: 4th Nov 2007, 10:05 -
Help: No sound at all with a Winfast TV2000 XP Deluxe
By Deathwish238 in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2007, 13:01 -
Leadtek Winfast TV2000 xp deluxe help
By Nuwanda in forum Capturing and VCRReplies: 0Last Post: 6th Jun 2007, 14:22
