For some months i'm the happy owner of a Nec1100a, but since a week i got a weird problem.
Windows XP keeps telling me the DVD+R writer is a CD player. It's also impossible to select the writer in Nero.
I already formatted my harddisk, and reinstalled xp, but that didn't seem to help![]()
Since i got problem i have been able to burn a CD with discjuggler, but i want to burn with nero!
Someone knows what's wrong here?
Is this a Dell system? If so, did the drive come with the Dell system? When you re-installed were you asked for the location of the device drivers?
It isn't a dell
winXP did install the default drivers when i re-installed it. It didn't even ask me where to get the drivers from -
Have you tried manualing installing the drivers for the drive. That may make a difference. Windows default drivers are probably not problem. Is your bios recognizing the right drive spec. Post back if this doesn't help.
What type of PC is it? The only drivers that are involved would be for the ide chipset, there is no NEC 1100 driver as it is a standard ATAPI device. I would find out the chipset and get the lastest drivers installed, i.e. Hyperion for VIA and serveral for Intel.
Intel drivers: http://www.intel.com/support/chipsets/driver.htm
Via drivers: http://www.viaarena.com/?PageID=300
SIS drivers: http://download.sis.com/sisdlc/driver_select.jsp
Hope this helps!
How to convert .SDV files to something WMM recognizes
By Carppacio in forum Newbie / General discussionsReplies: 0Last Post: 1st Dec 2010, 21:21 -
My computer no longer recognizes my Panasonic mini-DV recorder
By mjv in forum Capturing and VCRReplies: 1Last Post: 23rd Dec 2009, 15:25 -
ffmpeg no longer recognizes new mkv files
By pliniusfogg in forum ffmpegX general discussionReplies: 2Last Post: 7th Jul 2009, 22:44 -
2 SATA Drives - 1 drive letter in WINXP
By anthonyfellows in forum ComputerReplies: 8Last Post: 27th Feb 2008, 12:30 -
when captured avi goes over 4 gigs nothing recognizes it ?
By 99teggsr in forum Capturing and VCRReplies: 11Last Post: 28th Dec 2007, 23:00
