I was wondering is there a tool out there that will take a mpeg and turn it into a avi with audio without quality lost? i used dvd2avi and the vfapi but i lose the audio becasue the d2v file i get from dvd2avi dos not include to audio. Anyone esle have any suggestions?
Thanks for any help you could possibly give![]()
What are you aiming to do?
Do you mean take an MPEG as big as a whole DVD, and convert it with no quality loss to an avi file?
Well, it's going to take a lot of discspace, but you could use VirtualDubMod to open the MPEG2 file (use SmartRipper or something similar to rip the DVD to one vob on your hard drive if you need to), and then output to an avi in a format such as HuffyUV (which is lossless).
This will be a massive file though. Very, very big!!
Maybe I'm misunderstanding something - what are you actually trying to achieve?
cheers,
mcdruid. -
thanks for the info, it looks like virtualdub will do the trick. what i am needing is something to create avi from mpeg. i have alot of small clips from a dv camcorder that i want to make into avi's.
thanks again
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
Converting AVI file to mpeg 2 question.
By ingeborgdot in forum Video ConversionReplies: 17Last Post: 7th Nov 2008, 20:49 -
avi dvix, mpeg quicktime dvd quality question
By minmin2003 in forum Newbie / General discussionsReplies: 2Last Post: 26th Aug 2007, 12:16 -
Dumbass Newbie Question: MPEG or AVI?
By grahamh in forum Capturing and VCRReplies: 13Last Post: 16th Aug 2007, 06:20 -
Question: Freeware AVI To MPEG-2 Batch Encoder?
By Jeremy of Many in forum Video ConversionReplies: 36Last Post: 27th Jun 2007, 18:25
