I have an MP3 encoded audio on a CD-RW which is 95 MB. I want to burn the music on another CDR as audio CD. I am trying to use windowns media player and its says that data is huge and won't fit.
I am OK with truncating last 30 MB to put whatever can on the audio CD.
Can someone please tell me the easy way to do so.
Ray
Sorry Ray,
not following what you want to do.
when you play your MP3 file, how long is it ?
you can fit 80 mins on a CD
what software are you using to burn? Nero lets you cut the song so it will fit on a CD, other burning software should do this as well -
Oops I forgot to mention the total time for playing is 1:44 min.
Is there some way to put firt 70 mins on one CD and remaining on another.
Thx -
when you play your mp3 file , how long is it in minutes ?
the size of the mp3 dosnt really matter
when you burn the mp3 to a audio cd it converts it to a WAV/CDA type file which maybe too big for a CD.
is it a full album or long mix -
OK, just saw your other post
So its 1 hour and 44 mins
you can put first 70 mins on one cd and the rest on another
Nero will let you do it
add your mp3 into your CD and nero will say its too big then just change the end time of the song
do again for next cd and just change the start time -
Or you could put 98 mins on a 99min cdr and the rest on another cd. they work well in most situations.
The electronic components of the power part adopted a lot of Rubycons.
I lost audio for mp3's, .avi, mpg files, and Audio Switcher::Out
By HartsVideo in forum Software PlayingReplies: 13Last Post: 14th Oct 2012, 21:20 -
can i truncate mpeg1 video files without re-encoding?
By dullrazor in forum Newbie / General discussionsReplies: 2Last Post: 22nd Nov 2009, 16:47 -
MPEG2 Video with AC3 audio cannot convert to MP3 audio
By wenglock in forum ffmpegX general discussionReplies: 0Last Post: 7th Sep 2009, 22:52 -
Mp3 to Mp3? Audio Compresstion / Down sampling?
By YuJay in forum AudioReplies: 7Last Post: 7th Dec 2008, 13:05
