hi
i am a returning to encodeing vcds now heres my problem.
i am using the latest tmpengc with the divx 3,11 alpa codecs...and my dvd player is an apex ad-1110 player...i only use the old codecs cuz i bought a 40 dollar dvd player![]()
now heres the questions..
1.is there any problems with the latest tmpge??
2.is my dvd player EVEN capable of playing vcd 2.0 or Svcds correctly??
3.i didnt have these problems on my old ad 1100w model.
4.when i was using the old tmpgenc i didnt have these problems and if i am not mistaken i had MORE choices with the encoding settings..
5.i am not a newb at encoding vcds so i know what i am doing..
6.what type of cdr do you guys reccomend me to use for vcds and svcds??
7.how come on my new dvd player some of my vcds play in like slow motion??...again i dont know if the bit rate is too high or its the media i am using![]()
can anyone please tell me what i am doing wrong??
BTW heres my settings in tmpgnc
1.vcd 70 mins
2.704x480
3.full screen keep aspect ratio 2
thats all i can thibnk of for now i am not at home right now so i cant be 100 percent sure what my settings are![]()
a vcd is not 704x480.
it should be 352x240.
what you are making is an Xvcd and maybe thats why your player is giving you a hard time.
try it with the proper settings and see what you get.
just load the vcd Template in tmpeg.HELL AINT A BAD PLACE TO BE -
My Apex 1201 is $40 US on sale and plays anything.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
well i be i found out the problem quick it seems ANYTHING encoded by tmpgenc is all glitchy on my apex 1110w player
while the vcds i encode using nero burning rom work flawlessly regardless of which type of media i use 8)
anyway now that the problem is fixed can anyone of you guys reccomend me ANOTHER program that encodes and burns vcd like nero burning rom??
THANKS!!
Vcd audio problems
By Ak_wf1 in forum AudioReplies: 5Last Post: 26th Nov 2011, 21:19 -
Vcd audio problems
By Ak_wf1 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 26th Nov 2011, 20:59 -
Vegas- So many problems! What am I doing Wrong? Please HELP!
By i_c_e in forum EditingReplies: 23Last Post: 19th Mar 2009, 21:36 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Follow up : audio problems with VCD authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 5Last Post: 9th Jun 2007, 19:34
