Results 1 to 9 of 9
  1. I am trying to convert an avi media file using TMPGenc Plus 2.5.
    I extracted the audio to a wav file from the avi using Virtualdub. I then selected avi video only in TMPGenc and audio was the extracted wav file.
    After only 3% of converting, TMPGenc throws up an error message:
    Index of scan line is out of range (272)
    Anyone know what this means and how it can be overcome?
    Bob Heselwood
    Aug 2002
    Pittsburgh, PA, USA
    I have never seen that particular error. Could you frameserve it to TMPGEnc using VDub and see if that works ?
  3. err, How do I do that that...frameserve it to TMPGenc using VirtgualDub?
    Bob Heselwood
    May 2003
    Pal Realm
    There's no place like 127.0.0.1
    The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
  5. Ok, thanks for the helpful link, but:
    when I start and load the avi file into VD, VD complains about the cbr of the avi file. That is why I extracted the audio as a wav file etc etc. Anyway, I then run or click on 'start frameserver', then a save as box appears, and I save the file? as somefile.vdr. Then nothing happens; the saved vdr file is only 1kb with one line in it.
    So I then followed next step, and loaded TMPGenc, and tried to load the *.vdr file as source, but TMPGenc complained that the file was not supported.
    Help please. What next?
    Bob Heselwood
    Apr 2002
    The State of Frustration
    Hello.
  7. Thanks for the link, but TMPGenc now complains 'Illegal stream format' when I try to load the 1kb, single line *.vdr file.
    What next please?
    Bob Heselwood
  8. Ok, I found a bit more help on this site on how to frameserve with VD, and I saved the file as somefile.vdr.avi. Now that file will show as a clip only in TMPGenc. What else should I do here now that I know how to frameserve?
    So because the video avi and wav audio conversion makes TMPGenc fall over after a short time....source position 2.52, which is where it stops playing video. What can I do now to get the avi file converted to mpg?
    Bob Heselwood
    Apr 2002
    Okay, If you have TMPGEnc open select Video Browse-->All file types. Loaf for the .vdr file you just named (I always label itvdr.vdr). Once it is selected and you select OK select Start. It should start encoding the video from Virtual Dub.
    Hello.
