Will avi's burnt directly to DVDR/CDR play on a standalone Divx player? I am about purchase the latest Yamada player and not sure if its this straight forward. After I have merged seperate avi's I want burn it onto one dvd instead of having 2 seperate discs.
Anyone? (this maybe in the wrong section)
cheers!![]()
In theory, yes. In reality? Well, there's a world of differences in MPEG4's. You can go from old DivX 3.11 low motion codec under-bitrated crap to 2.1 GB DivX 5.10 OMFG impressive 720x40 encodes. Don't expect the palyer to treat each the same.
Most DivX are made to fit a disk, not give you DVD Quality. Also, a lot of DivX have odd resolutions and odd framerates, don't expect the player to deal with that very well. Certain advanced MPEG4 features probably won't be supported untilthe future, if at all.
Basically you will want to re-encode your DVD's to some standard DivX resolution/bitrate. To keep DVD quality, you can expect to get 2-3 movies per DVD. But, for a 3 hour action flick on a DVD9, don't bother, just re-encode it to 1 DVD.To Be, Or, Not To Be, That, Is The Gazorgan Plan
Want to purchase good DVD Upconverting 2.0 USB Player in Canada
By scharfg in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Jan 2010, 23:50 -
DIVX player question
By slats7 in forum Video Streaming DownloadingReplies: 4Last Post: 25th Sep 2008, 07:10 -
A Question about upconverters and what DVDs to purchase
By FFPOLLARD in forum DVB / IPTVReplies: 3Last Post: 25th Apr 2008, 08:39 -
If I purchase a low end DVD player just to watch movies....
By leftyloopy in forum DVD & Blu-ray PlayersReplies: 8Last Post: 12th Feb 2008, 14:02 -
Yamada 5520 DVD Player - Remote
By paulXLE in forum DVD & Blu-ray PlayersReplies: 0Last Post: 18th Aug 2007, 11:24
