HELP!!!
Tried to play a SVCD on my Pioneer dv-535. The screen stays dark/blue. It says it´s playing a vcd but it doesn´t show any movie. Could someone please help me out? The movie has a swedish subtitle, could that be a problem? I have played vcd´s on it before without any problems what so ever...
Kind regards,
Matti, Karlstad, Sweden
Sounds like your player doesn't support SVCD's. Check out here:
https://www.videohelp.com/dvdplayers
for whether or not your player can do SVCD's.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Thanks but I have allready checked that page out, and it says that my dvd should play svcd´s, but maybe I´m just dumb... No other ideas???
Download and burn one of the SVCD test files.
Your SVCD may not be 100% complient, which is giving you player fits. The fact that it says VCD and not SVCD means it recognizes the CD, and that it has video....but it's not rendering it correctly.
Research 'VCD Header Trick', which is a way to fool some players into playing SVCDs. Alternately go spend $40 US on an Apex 1201 that plays anything........To Be, Or, Not To Be, That, Is The Gazorgan Plan -
This may sound wierd, but try this:
Run a DVD movie in your player for 5-10 minutes. Let it build up some heat. Then play your SVCD. My Pioneer player has problems with (S)VCDs (and audio CDs) when cold.
Darryl -
movie play computer??
The electronic components of the power part adopted a lot of Rubycons.
FAQ -Common playing problems!
By Baldrick in forum Software PlayingReplies: 8Last Post: 28th Jul 2014, 05:15 -
Problems playing Hi 8 tapes with my camera
By roscoe47 in forum Newbie / General discussionsReplies: 1Last Post: 12th Jul 2011, 11:43 -
Anybody Else Have Problems Playing MP4s With Quicktime?
By phild in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2008, 12:01 -
MPEG playing problems
By Dave Knowles in forum Software PlayingReplies: 5Last Post: 14th Oct 2007, 07:31 -
Problems with recorded TV playing
By amir77a in forum Media Center PC / MediaCentersReplies: 4Last Post: 15th Jun 2007, 07:57
