How do I make another picture show when a picture link is clicked?
[img]URL[/img]
Is it possible; where do I put the code?
Results 1 to 27 of 27
Isn't it "$FF0000"?
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
You talking about placing a thumbnail of a picture and then click on it to make it bigger?Originally Posted by g_shocker182
here ya go
<a href="picture.gif">
[img]picture_small.gif[/img]
If you're talking about clicking a picture and going to a new web page
here ya go
<a href="http://www.dvdrhelp.com">
[img]picture.gif[/img]</a> -
nevermind :cD deleted - thought someone answered my brainless question. :co
forgive - bad dayThere's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
which one?Originally Posted by Gees
Ahh I'm not going to say! I want it to die! But Gshocker added to it and revived the d__n thing again and then I got confused & panicked and thought it was the same you added to.
:cD
I know html, but had a bit of trouble using it with bb code for signatures. That was all :c* I knew how to do it within posts, but in profile there were no handy one click buttons. :c*There's no place like 127.0.0.1
Ahh, yes I saw that one, but someone reply with the answer before I read it :P
Yeah :c) I got it. See, I have been doing "<"s for ages. Was hard to make the change to "[". My brain fought it. :cD Too big a leap, I guess.
If I had a penny for every "<" I've typed - I'd be rich and sharing the wealth by now. :c)There's no place like 127.0.0.1
stiltman, I'm a little confused by your post.
I have this picture up by default:
And the code is:
[img]1.jpg[/img]
But what I want to do is to have it so when a person clicks the picture (and holds) for the other one to show:
And once they do that they will be redirected toward the off-site link.
Sorry If you explained it right the first time, but I didn't understand it. -
G shocker - first - sorry I interrupted your thread before & Stilt will probably be back in here, but wouldn't you prefer it change as the mouse rolls over? rather than when clicked?
I say that because people don't usually hold a click down & you can do mouseover image swaps with little javascript codes - even a 3rd image on click - if you want. :c)There's no place like 127.0.0.1
Yes, but that split second it would be cool to see an the inverted image.Originally Posted by Gees
True :c) I just thought anyone might miss it, as it passes so fast.
Unless you are trying for subliminal messages! ;cD
Anyway - just thought I'd mention it. :c)
Oh - I got my Office Space today. Loved it! :c)))There's no place like 127.0.0.1
Sounds to me that you want it to change to the other picture when the mouse goes over it and then if you click on it, it goes to a new page or picture?
In that case
you need to use a java script
Are you using FrontPage to edit your pages?
If yes, it's fairly easy to to this -
you can still do that - exactly what you want. It just needs a little javascript for "onclick" :c))
Do you want that? Lots of free cut-and-paste scripts out there. Need help tracking one down?
This will do that, but it will not redirect to another web page. It will just change the picture
<a href="picture1.gif">
[img]picture2.gif[/img] -
Actually, yeah. Too many scripts out there to find a single one.Originally Posted by Gees
OK. :c) So, are you doing this straight in notepad or an html editor?
1:27 no answer :c*
well, if you still want it - PM me the filenames and url and I'll build it for you if you still want it. I don't need the actual images, just the names, so you don't have to change anything.There's no place like 127.0.0.1
I do straight up notepad and am proficient with HTML. If you just make a message here with a link or s/t I would appreciate it.
Thanks! -
Had to go to sleep last night and can't find one quickly this morning, so made one:
<html>
<head>
<title>Image swap</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<script language="JavaScript" type="text/JavaScript">
function MM_preloadImages() { //v3.0
var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
function MM_swapImgRestore() { //v3.0
var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a[i])&&x.oSrc;i++) x.src=x.oSrc;
function MM_findObj(n, d) { //v4.01
var p,i,x; if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
if(!x && d.getElementById) x=d.getElementById(n); return x;
function MM_swapImage() { //v3.0
var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3)
if ((x=MM_findObj(a[i]))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];}
</script>
</head>
<body onLoad="MM_preloadImages('Image2.jpg')">
[img]Image1.jpg[/img]
</body>
</html>
Any questions, just shout. :c) This one includes a pre-loader.There's no place like 127.0.0.1
BTW - no thank you - no comment but ....... you're welcome anyway :c*
if you thinking of putting HTML here, you can forget about it koz
it's disabled. But some of these can still be done using BBcode.
.swf in html help
By mraza in forum Newbie / General discussionsReplies: 1Last Post: 31st Aug 2009, 16:15 -
7z.html files???
By Glenn5782 in forum Newbie / General discussionsReplies: 3Last Post: 17th Mar 2009, 04:43 -
html help
By steve42069 in forum ComputerReplies: 4Last Post: 8th Aug 2008, 10:38 -
HTML Help
By FEEL in forum ProgrammingReplies: 3Last Post: 20th Aug 2007, 08:58 -
html in forum
By Ogilvy in forum FeedbackReplies: 4Last Post: 13th Jul 2007, 18:30
