Basically i have some SVCD's that i would like to convert into Pal DVD's to play on my Playstation 2.
I Extract the file using ISO buster to my harddrive, then i have to convert this into i tihnk tis MPEG 2.
I would normally use TMPGEnc like i do for others, but i get errors about the resulution being 480 x 480 which isnt DVD size, so ive followed some other guides, and multiplexed and demulpilexed and joined them or whatever, (one of the guide on this site somewhere)
then used DVD patcher to patch the first header, and also convert it into PAL format.
Problem is after thats done, TMPGEnc still wont read it. Either will TMPGEnc author
So i tried to used Ulead Movie factory 2, and this just crashed.
Any one got any Idea's?
thanks
nat
Results 1 to 1 of 1
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 17:46 -
converting PAL DVD to NTSC while preserving chapters
By andreyvul in forum LinuxReplies: 10Last Post: 2nd Sep 2009, 04:04 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 02:47 -
converting PAL AVIs into NTSC DVD
By exekutive in forum ffmpegX general discussionReplies: 0Last Post: 24th Jun 2007, 19:20 -
Converting an NTSC DVD to PAL w/ DTS
By thisismyname07 in forum Authoring (DVD)Replies: 28Last Post: 27th May 2007, 00:57
