HI IVE JUST GOT IN TO BURNING DVD-R'S AND IVE BEEN USING CLONE DVD + SOMETIMES NERO EXPRESS ON NERO 6, SO FAR ALL THE DISCS PLAY FINE ON MY PACIFIC 1002 AND MY PC BUT THEY PAUSE LIKE HELL ON MY PS2 AND MY MUVA'S YELO PLAYER IS THIS THE SPEED IM BURNING THE DISCS AT WHICH IS 4X BUT IM USING A PIONEER 106 AND 4X DISCS? WHATS THE BEST SOFTWARE TO AID THIS PROBLEM?
MY MATE USES RECORD NOW MAX AND SES HE HAS NO PROBLEMS WITH IT? WHAT DO YOU ALL THINK????
LOVEJOY
SORRY ABOUT THE CAPS forgot just realized
lovejoy
Results 1 to 14 of 14
what media are you using ? .. is it + or - r, what brand is it,what model of ps2 areyou using? answers to these basic questions will make it easier to diagnose your problem
PS2's are notoriously picky about certain media.
PLUS, IT'S NOT POLITE TO YELL!
(On the Internet, using all capital letters means you're YELLING!)
- Gurm -
sorry about the yelling fella's, im using dvd-r 2x4x premium grade A discs, im burning with a Pioneer 106 dvd re-writer, im using Dvd Fab to rip dvds and nero 6 express to burn them at 4x! Once burnt they work fine on my Pacific 1002 dvd player but pause on my Ps2 and Yello dvd player! Ive heard that nero is full of glitches and Record now max is the boy for dvd-r burning and that to try burning them on 2x instead of 4x
Foo, it would be nice if you actually offered some real advice once in a while rather than your "amusing" quips. Not only are you flaccid, but you are a total bore.
Yeah, I know. You know 10 kazillion times more than I do. But how about a little civility once in a while?
You create your own reality. Interested in media servers and HTPC? Can we talk? -
Lovejoy - you already started a post about that earlier tonight here: https://www.videohelp.com/forum/viewtopic.php?p=673443#673443
Please, if you want to ignore what I already told you, wait for more replies from others in your first post, or add to or change it's subject title. It's really unfair that now more people have restated what I already told you.
I did mention this the last time you had 4 different posts in one night.
Be fair to those that are trying to help you.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
hmmmm, I'm sure someone raised this issue before :POriginally Posted by hothandiman
Hey for what it's worth, all lowercase isn't much better than all caps.
There was another guy here that used all lowercase.
in fact
he used all lower
case and put every
thing on its own
line sometimes and forgot
all his punctuation so
i wonder what happened
I'm not picking on you. Just Vance.
- Gurm -
for what it's worth????
it's worth absolutely nothing!
WTF has CAPS or lowercase got to do with anything in this post, are you still hurting over vance43211???????
the actual problem with some people on this board is that they are too keen to jump on someone for making a silly mistake so they think they look clever. You heroes!!!!
and what I'm amazed at is the fact the guy actually realised and apologised yet the issue is still raised. Why not just let it go in the 1st place as his previous posts haven't been in CAPS. Some people on this forum just take things too far for the smallest things
sAd vErY SaD iNdEeD!
I guess some people will never change, always the usual suspects and that's why I stay at Doom9 more even though I like this board, because I don't see stupid childish immature shite like this every other post
peace people -
"premium grade A discs" hmm.. that sounds very suspicious right there.Originally Posted by lovejoy
If you could post the media code generated by DVDinfo that would help.
Also Nero 6 blows. But I doubt that is causing the problems, you may have to burn as UDF 1.02 instead of DVD video my friend's PS2 will only read on TDK media burned at 2.4x w/UDF1.02.
then again I can throw anything at mine and it's fine... same model and revision numbers too.. -
Mack, CHILL.
You'll note that I tried to help as well.
1. Get some good media. "Premium GradeA Discs" usually translates to "Cheapest media available with a snazzy name". Get some Ritek or Ricoh discs. If you've got a Best Buy or Staples near you, get some Fuji discs retail. They're really good. I NO LONGER recommend Verbatim, because they switched from Ricoh to some crappy no-name.
2. You can TRY burning at 2x. But really the only reason for this is if the media is too bad to be burnt properly at 4x, or if your system can't keep up. I think the media probably IS bad, so MAYBE burning at 2x might help.
- Gurm
Anyone here use 3DS MAX?
By Rudyard in forum ComputerReplies: 5Last Post: 25th Jul 2012, 13:53 -
Max Mp4 player
By drrino in forum Portable VideoReplies: 1Last Post: 28th Feb 2012, 00:04 -
Xvid.Max conversion
By hawkeye48 in forum Video ConversionReplies: 0Last Post: 26th Jun 2011, 02:48 -
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 18th May 2010, 23:35 -
MPEG-2 max bitrate
By Sjakko in forum EditingReplies: 16Last Post: 12th Jun 2009, 11:29
