i have a dvd that i want to add ac3 to, but i dont want to have to reecode it. so isit possiable to to sort of un-authhuer it so i have a mpeg 2 dvd compable file that i can exstact the from audio and the convert the audio to ac3 then athuer it back together again????
Results 1 to 15 of 15
sure you can do it pretty easy -- but to what end ? you are not going to get any better quality
i no i want get anymore quilty, im not after that, im after adding ac3 5.1 surround sound to it, so can u tell me how to do it
You should post your questions before you drink your six-pack,
not after.
Actually this is an interesting topic. The AC3 has compression as compared to the LPCM that most DVD Authoring tool utilize. I would love to know how to convert it to an AC3 stream. I have been reading the besweat and think this is the avenue to go.
Is it too much to ask for you to use proper grammar? It's hard enough to answer your question when you can't exactly specify what you want, but even worse when I have to decode your cryptic "english". And you can probably find your shift key too if you look hard enough for it (hint: there are two of them).
Darryl -
its quit easy to do, but i wouldnt bother with the beesweet rout i tryed that and it didnt work, get a little program called soft encode 5.1, its very easy to use and itll give real 5.1 were as i dont think beesweet can do that, it only gives you 2 channel audio.Originally Posted by dun4cheap
silk purse sows ear // You CANT make 5.1 sound from stereo.. you can fool around and re-encode all you want .. its still stereo coming from 6 speakers instead of 2.
sixpack. shhpelling ..Corned beef is now made to a higher standard than at any time in history.
I'll shall take it, that no one has heard off a little programe called Sonic Foundry Soft Encode - Dolby Digital 5.1 ?????????????
And wot is this, i came on to this forum for help with somthing, not to get pulled down, for my spelling, for anyone who would like to no,im dislexic, thats why my spelling is not to good. -
mark845,
Ignore the geeks that love to pick on people's grammer and spelling abilities.
If you do enough searching, you will find many errors they have made on this forum.
Keep posting your questions and you will get help. There are a lot of very helpfull people here.
LS
PS God, I hope I spelled everything right....... -
Ok, I am dyslexic and that is the most lame excuse that I have ever heard.
Hunting, sure i'll go hunting. When is cow season? -
its still only 2 channels .. just that they will be coming out everywhere -- most receivers do a better job of simulated surround .
im alittl bit pisapointed to hear that, as i realy thought it was the real deal surround sound, as the Dolby Digital light comes on, on my dvd palyer, and it comes on, on my recevier. also somtimes i have to use dvd2one to transcode my movies down when ive add the ac3, and dvd20ne also picks it up as dolby digital.Originally Posted by BJ_M
dolby digital can be 1 , 2 mono , 2 channel stereo, 3 channel stereo, 4 or 5 or 6 or 7 or 8 channels .. no mater what - if it wasnt mixed in surround (or recorded) , it isnt surround, you can simulate it by using delays on the rear channels and such .. but just becuase its dolby (or dts) doesnt mean its true surround ..
re-encoding dolby or any compressed format will cause quality loss .. its better to use the orig. 2ch and use the receiver to simulate surround (if desired)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
