Hi,
I started using the TMPGenc DVD Author and i am very happy with it.
Now I would like to create another menu with the same structure as the original Blue theme has. Basically I just wanted to modify the Blue menu (change the font type and color, position of text), but because it is not possible I decided to create another menu. Unfortunately, I do not know how to generate the same structure as the Blue menu theme has.
Please help me if you can!
You can still use the old menu templates, eg blue etc, they are available on the left hand side drop box under create menus.
That was my question: how to do?
Could you tell me a little more details?
Thanks for your help. -
If you start new project then add DVD video button to import your authord dvd.
This will keep all the cahpter's and pages that were set up but will revert to the default theme's. -
Hey guys! Are you kidding with me? Or was I not exact enough?
I am talking about creating a NEW MENU THEME, not creating a certain menu.
Of course, I know how to import a DVD Video folder, how to keep the chapters and how to set up the menu. My question is how to create a new menu theme in the TMPGenc DVD Author, which I could save and use it any time I wish.
To be exact, I know how to create a new menu theme, but I could not see any possibilities to generate the same structure as the Blue menu has. Initially i just wanted to modify the text the position and the fonts in the Blue menu, but it was not possible. That was why I decided to create a new menu THEME with the same structure as the Blue menu has. But i was not able to figure out a way how to do it. I could only do a similar to the Cloud1.
I hope, I am exact enough now.
Please help me if you can.
Thanks in advance.
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 19:20 -
TMPGEnc DVD Author 1.6 thumbnail menu issue
By Bix in forum Authoring (DVD)Replies: 0Last Post: 3rd Oct 2007, 10:00 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 19:43 -
TmpgEnc DVD Author 3 - Question About Menu Music
By heyjjjaded in forum Authoring (DVD)Replies: 10Last Post: 30th Jul 2007, 13:16 -
Menu troubleshoot using Tmpgenc Dvd Author
By tekka06 in forum Authoring (DVD)Replies: 8Last Post: 4th Jul 2007, 03:53
