Im in the market for a DVD Writer, what would you recommend for me, i have a Settop DVD Player Hitachi DVP325u, what DVD Writer would make a DVD best for that player?
the best a man can get!
I'd recommend you read through the WRITER database on the left. People leave comments about their writers - success and horror stories.
Only you know what criteria you have in mind. Try there first, narrow your choices, then use the search box on this page to find more threads of comments, problems and resolutions on those you are deciding between.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
I'd say the most recommendations for dual format at 4x and value is the Pioneer 106D at Newegg for $155. The Plextor is also recommeded for speed at 8x for plus, but its $235. Others to consider is the Lite-on 401s for $105 (which may be firmware upgradeable to do minus ...its being experimented with right now) and the NEC 1300 at $130.
PAL -> NTSC DVD Writers?
By tac7 in forum DVD & Blu-ray WritersReplies: 4Last Post: 2nd Aug 2010, 22:34 -
Sony and Optiarc DVD writers
By anfield7 in forum DVD & Blu-ray WritersReplies: 2Last Post: 1st Oct 2009, 23:44 -
XP does not recognize my DVD writers as DVD writers thinks they're CD write
By steve1040 in forum DVD & Blu-ray WritersReplies: 5Last Post: 25th Jul 2008, 02:52 -
Better DVD Writers
By gameroftheuk in forum DVD & Blu-ray WritersReplies: 2Last Post: 30th Sep 2007, 14:51 -
Buying 2 SATA DVD Writers
By mis3 in forum DVD & Blu-ray WritersReplies: 3Last Post: 13th Aug 2007, 23:08
