I don't know what happened but I now cannot put my cpu into standby mode. When I go to Start,Turn off computer, and then my three choices come up to restart,turn off, or standby, the standby button is greyed out. Any ideas on how to enable standby again? I am running windows xp.
Does your computer support a hibernation mode? Not all computers support that, especially desktops. I believe that Windows XP normally has the standby option available by default if the computer has the proper equipment and is configured in the BIOS.
"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
XP disables my Standby mode when the machine (on the previous boot) shows signs of instability.
right click on desktopOriginally Posted by rubberbed
select properties
select screensaver tab
select power button
select hibernate tab
put a check mark in the box if it's not there
click apply
click ok
click ok -
can't help ya there....sorry but it sounds like your BIOS doesn't have that option. Try going to the MB manufactuer to see if it's compatible and if there's any BIOS updates
Dell Monitor goes into Standby mode
By Soixante in forum ComputerReplies: 8Last Post: 17th Dec 2011, 09:35 -
Pc monitor goes to Standby Computer wont Boot
By Soixante in forum ComputerReplies: 7Last Post: 1st Apr 2010, 13:48 -
Do you shutdown your computer, leave it on, or put it in standby?
By yoda313 in forum PollsReplies: 21Last Post: 7th Aug 2008, 17:21 -
Samsung P171 STANDBY
By ionutzcena in forum DVD & Blu-ray RecordersReplies: 0Last Post: 3rd Aug 2008, 04:51 -
Mouse/Keyboard dose not work after coming out of Standby or hibernation
By noki in forum ComputerReplies: 13Last Post: 7th Jun 2007, 10:00
