Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
    Feb 2003
    Netherlands
    Hi all,
    Products:
    I just bought a NEC1300A, I have not update to the latest firmware yet.
    I use NERO-6 to burn.
    Media is Datawrite red label
    Problem:
    When burn a DVD-R with NERO-6 I see my buffer drop to zero at 91% during the burn process.
    Before starting the burn, Nero said that my dvd player and burner are on the same IDE so it might have this problem, I tried it any way, and yes nero was right
    I then swapped my IDE's so now each drive is on a IDE with one of mine HDD.
    tried again and still the same problem at the same time ( 91% )
    I did NOT get the Nero warning msg, tough.
    I then tried to copy and paste the VIDEO_TS files to my HDD but i got an error.
    I then tried DVD Shrink 2.3 and 3 but they gave me an error at the start.
    I tried DXCXpress but the same as DVD Shrink
    I then use DVD Decrypter but it also hangs at 91%, so i then tried to make a ISO file from the VIDEO_TS files but it hangs on 71%.
    I am running out of options here, can some one help me burn this movie?
    many thx in advanced.
    Greets, Mysterio
  2. Pretty sure Datawrite red x4 is not compatable with the nec 1300A. TIP do not place a dvd\cd rom drive on the same ide channel as your HD
    Feb 2003
    Netherlands
    Hi,
    Can someone tell me what media to use with a NEC 1300A?
    thx. in adv.
    Greets, Mysterio
    May 2003
    Belford, NJ
    the following discs burnt well for me in the NEC ND-1300A:
    TDK 2X DVD-R
    Ritek G04 4X DVD-R
    Optodisk DVD-RW (2X Write, 1X Re-Write)
    Memorex 4X DVD+R
    I haven't tested a lot of different media, for the most part I stick with what works.
    Aug 2003
    Germany
    all u nec 1300a users, try herries firmware 1.07v3 then there are a lot of more medias u can burn. http://herrie.rpc1.org/
    its a hacked one with windows installer and there are a lot of cheaper medias added, u dont need 2 buy that expensive stuff for about 2 bugs a DVD-R!
    It worked very well for me!
    *just another noob*
  6. Arita x4 +R
    Infiniti x2.4 +R
    Bulkpaq Greentop -R
    all been OK.
    Life is what happens just when you've got everything planned.
