Hi,
I've capture a video at 480*576 (PAL SVCD) with virtualdub and mjpeg codec. I capture it from an analog source with a WinTV card.
Do I need to deinterlace it to encode to SVCD ???????
I can see horizontal lines (like an interlaced video).
To make simple, here is a screenshot (wait a few seconds, the server is not very fast):
If I need to deinterlace which Avisynth filter do I need to use ???
Thanks.
Do not de-interlace. SVCD is mpeg-2 which supports interlaced video, just encode as interlaced.
To check out your capture properly, do not use WMP, play it in PowerDVD which has a built in on-the fly de-interlacer. This is neccessary on your PC monitor which is not an interlaced display. A TV is interlaced so it will look ok on there. -
I agree to leaving it interlaced...
seems however that you need to swap the fields...
Deinterlace
By leftspeaker2000 in forum DVD RippingReplies: 2Last Post: 5th Dec 2011, 05:17 -
How to deinterlace with xillisoft
By Vman94 in forum Video ConversionReplies: 4Last Post: 8th Sep 2011, 18:55 -
Deinterlace?
By ZedsDead in forum Video ConversionReplies: 6Last Post: 14th Mar 2010, 23:21 -
To deinterlace or not deinterlace...
By Nilfennasion in forum MacReplies: 4Last Post: 4th Dec 2008, 00:46 -
Do I need to deinterlace? Or never deinterlace?
By rbatty11 in forum Video ConversionReplies: 12Last Post: 17th Jan 2008, 13:15
