I need PAL-Video MPEG1, 352x288 Pixel, 4:3 625 line, 25 fps, CBR Bitrate 1150 for VCD. TMPG-Encoder works fine.
But with VideoWave4 it works only in 2 Steps although the settings seem to be the same (MPEG1 PAL). After WideoWave-Conversion I have to convert the movie for a second time with TMPG-Encoder (The file will shrink again to nearly half size.) Then the Burning-Software Nero 5.5) will accept straight.
Does anyone know how to do that in 1 step with VideoWave4???
There should be two templates. Mpeg-1 and Video CD.
Try using the videoCD template.
Automated Wave joiner.
By odomike in forum AudioReplies: 6Last Post: 28th Apr 2012, 02:26 -
Reduction of a wave file from 35 MB to 24 MB How?
By andy jackson in forum AudioReplies: 4Last Post: 1st Jun 2011, 11:41 -
Tsunami Wave on it's way here!
By budz in forum Off topicReplies: 20Last Post: 1st Mar 2010, 11:23 -
audio wave forms in video.
By kingtiger in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2009, 17:36 -
Wave Metadata
By loster in forum AudioReplies: 0Last Post: 1st Sep 2007, 09:45
