I don't really have a problem, but I have two files that equal one movie, they are MPEG3's. If I wanted to convert them into MPEG2, it would take up most of the DVD+R Disk, but was wondering if there was any way possible to convert them into atleast half the size of the disk without such a dramatic loss in quality?
Originally Posted by GeneSATXWant my help? Ask here! (not via PM!)
Sorry ??
You'll have to provide more information, you're confusing us .........
Install AVICodec or GSpot, these will tell you exactly what codec is used for video and audio, even if its not installed on your system
Obviously AVICodec only works fir AVI filetypes, GSpot should detect virtually any movie based filetype, not sure, don't use it that often -
AVICodec will work with all video types, MPEGProperties is another good one.
You could try EO Video,it can convert just about anything.
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 16:25 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
Premiere Pro CS3 can it convert avi to mpeg3 ?
By DBenz in forum Video ConversionReplies: 3Last Post: 13th Apr 2008, 14:42 -
Simple question: how to compress 4GB mpeg2 to 1GB mpeg2
By jimdagys in forum Newbie / General discussionsReplies: 29Last Post: 3rd Jan 2008, 08:45
