Anyone know of software that will convert an mpeg2 file at a possible 352x480 to a usable mpeg or avi stream that is also faster than the Trex software it comes with? It gives 4 choices
1 dvd
2 mpeg2 PS at 640x480 and 6Mbps
3 SVCD
4 DVavi which it converts my source to 360x480 48K audio, etc.
It just takes so damn long! There must be something else that will demux this stream and remux it into a proper mpeg stream. Thanks for any help.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
Womble MPEG2VCR ? Maybe ?
It's been so long since I got rid of my Bungee DVD, I don't remember.Want my help? Ask here! (not via PM!)
I'll try it. Also need to reload DVDmovie factory2 from a hard drive failure, that might work. Mediaplayer plays them, but it also says it is 640x480 or something strange like that. It has taken 2 hours to get to 62% on a PIII 750Mhz machine, and is only about 32 minutes in length. I think I'm going to have to abort because it is getting near time to record another couple of things.
Maybe until I find a better solution, I'll have to let it transcode while I sleep, and all the next day if need be. To bad they didn't make a true mpeg2 stream to begin with.Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
I think I may have found it. EditStudio 4 has the ability to parse mpeg streams when used with its mpegXS encoder. I have a test encoding right now from the Bungee files to an edited 352x480 at 3000 VBR and converting the audio to 48K for DVD use.
WTV/DVR-MS files into usable MPEG format?
By CursedLemon in forum Newbie / General discussionsReplies: 6Last Post: 24th Jul 2010, 10:21 -
ffmpegX doesn't produce usable files from FLV
By mdulude in forum ffmpegX general discussionReplies: 6Last Post: 15th Nov 2008, 06:43 -
RAM .vro files to usable format?
By nelsh in forum Newbie / General discussionsReplies: 2Last Post: 6th Nov 2007, 20:05 -
Need advice on converting MOD (mpeg2) files to usable format for iMovie
By InsanelyOne in forum MacReplies: 3Last Post: 9th Sep 2007, 16:23 -
trying to convert VOB TV files into something usable on my computer
By sipapu in forum Video ConversionReplies: 5Last Post: 27th Jun 2007, 12:49
