Ok guys, let's cut to the chase. What is the best way to make a VCD (i.e. convert an avi. to MPEG).
My friend said that the following method produces the best audio and visual result:
-Open avi. in VirtualDub
-Start frame server with the frame rate set to 25 fps
-Open TMPGEnc
-Select the frame served file and rip it to mpg
-Convert the audio in Besweet to the right fps
-Then Multiplex them
Sounds about right.Originally Posted by magic_impulsHis name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Thats sounds good...after you convert the files to an mpg, just use the mpeg tools in TMPGEnc to multiplex.
How to make flashes play normally in VCD?
By blair in forum Video ConversionReplies: 5Last Post: 20th Oct 2009, 06:14 -
How do I make my Samsung R150 recorder region free? I have the code to make
By charpee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jan 2008, 07:10 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 19:37 -
How to make an autorun VCD in English please!
By jimiir in forum Authoring (VCD/SVCD)Replies: 10Last Post: 8th Aug 2007, 23:56 -
Trying to make AVCD/VCD with audio data
By Vejita-sama in forum Authoring (VCD/SVCD)Replies: 2Last Post: 4th Aug 2007, 16:15
