  1. doesn't it capture in analog format AVI?
    May 2003
    Peterborough, England
    DV format is avi.
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    i only use it on one machine - but it captures fine in huffyuv and mjpeg and uncompressed
  4. I'm trying to run it and my capture hardware is MIRO DC-30 PRO under win98se, using its built in MJPEG CODEC. But it says "it cannot initialize this device" when i selected the Mirocaptureseries under capture drivers.
    any info will help
    tnx
    Aug 2002
    When I capture with AVI_IO I need to first start my bundled software ATI MMC TV and quit it to initialize my capture card. Perhaps it is the same for you, that you can initialize your hardware using another software and then go back to AVI_IO and capture?
    Ronny
  6. Just a thought,but any idea if your drivers are VFW or WDM based?
