I just received my LG 4040B DVD drive from a ebay purchase and cannot find any threads about flashing the filmware. I thought I had read here that I should do it. What is the benifit, where is the filmware to reflash it to and how do I do it. Believe me I searched befor I asked but maybe Im using the wrong terminoligy.
Any hel is greatly appreciated.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 21 of 21
Swing a hammer at it, if it doesn't fix it I gaurantee you will feel better.
Did you try just entering your model number in the search box on this page? Maybe someone's asked and answered before in existing threads.
Or look up your model in the database here. There's databases for Media, Players, Writers, & Capture cards. Perhaps someone's left useful info in the comments sections that will help you.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
http://us.lgservice.com/index_b2c.jsp
Click on Device Driver, then CD-RW, then find
New firmware Ver A300 for GSA-4040B DVD-Writer
Your search didn't find any threads because you misspelled firmware as "filmware." -
Wow, I have always read it as filmware. Thanks for the glasses.
Swing a hammer at it, if it doesn't fix it I gaurantee you will feel better. -
hey thanks lgmayka,
I just followed that link and downloaded the firmware. How do I know what version I currently have and how do you actually upgrade if neccessary?
Currently the drive is sitting in a box on my desk, I am still following the thread on how to correctly open the box!Swing a hammer at it, if it doesn't fix it I gaurantee you will feel better. -
Hi Duke
Unzip the firmware file and read the instructions. It tells you how to flash your drive. The included software would say what firmware your drive currently has. Make sure you follow the instruction strictly otherwise the firmware would not be effective. I went through the pain.
By the way lgmayka,
Did you figure out out your burning speed problem? My drive works really smooth now, CloneDVD has been treating me really good, backing up movies in about 14 mins. -
DUKE107: If I recall correctly, the firmware that comes with the drive is marked on the top of the drive. If it reads A300, your drive already has the latest firmware; if it reads A104 or such, you need the firmware update. After the drive is installed and has its own drive letter in Windows XP, you can right-click on the drive, select Properties and then Settings to see the firmware version.
rits399: No, I can still only burn at 2x. I am actually going so far as to wonder whether my spindle of RITEKG04 blanks was actually a mixture of American/Asian disks and European disks. According to another poster, LG Europe admits that the GSA-4040B will not be able to burn, at 4x, RITEKG04 disks that were manufactured for the European market, because the data layer thickness of such disks is too thin. -
I got some certified 4x dvd-r media from newegg.com but my LG 4040B burns them only at 2x despite the latest firmware. But, it can burn 4x dvd+r at 4x
A301 (kw) out... some saying they can burn princo's @ 4x now
Havent tried it myself though...
vattumannen: I downloaded the new Firmware too and now it works at 4X.
I've tested with Princo DVD-R and BULKDVD, burning software was
Nero 6.0 Ultra Edition.
Here is a link to the Firmware upgrade A301:
http://www.lge.co.kr/open_data/GSA-4040BA301(kw).zip10110101100111012011 <- The bug Bill doesn't talk about. -
I've upgraded to A301 now, and my drive now it recognises my princo discs as 4x
I just canīt read the Read Me (Kw).TXT file in the GSA-4040BA301(kw).zip file about LG 4040B Firmware update. When I open the file. :I see some like of this: #&ŋ" .&.
I download this file twice. Can somebody help me ? -
It's in Korean. I just ran the flash program since it was in English, everything went well, after the reboot my 4040's BIOS read A301.
Just run the update, it works!.
Princo 4x now burn in 14.5 minutes, 4.464 Gigs. -
I went onto LG web and only found the A300 firmware where did you get the A301?
Look up at the link that vattumennen gave in p0rnLiME's message.
If you need a english readme file you could always download an "older" firmware and read it's readme... It would be similar to the one you want, just imagine that it says A301 instead of A300.
Originally Posted by p0rnLiME
How to disable Microsoft Update, not Windows Update?
By ukb007 in forum ComputerReplies: 17Last Post: 8th May 2011, 15:52 -
How to Update Your Duplicator's BIOS. you need to update
By krrish in forum DVD & Blu-ray RecordersReplies: 1Last Post: 29th Apr 2011, 12:02 -
Please update me on sw :-)
By boeniz in forum DVD RippingReplies: 7Last Post: 13th Apr 2011, 08:15 -
Update to ffmpegX?
By Marc01FR in forum ffmpegX general discussionReplies: 2Last Post: 21st Jan 2011, 13:24 -
New update of Super
By coopgang in forum Video ConversionReplies: 10Last Post: 5th Jan 2009, 14:56
