Yes, give it a try!!
All of my sources have so far been 720x576 (I'm not into DivX downloads) but I have just recently purchased a satellite card for my PC which grabs the raw MPEG2 stream straight off the satellite. I've noticed that some stations there use odd frame sizes and the picture resolution looks bad compared to UK DTT - even though in theory they should be the same. I try not to re-encode anything and just burn the raw MPEG2 files straight onto DVDR, but with these oddball sizes, DVD authoring programmes don't accept the files and normally you have to re-encode. However I believe that there is a programme that lets you change the percieved frame size without re-encoding. Does it actually work? Would a DVD authoring package accept the modified files? Has anyone tried this before?
