  1. Aascudiero
    Guest
    I've never had a problem converting .MOV files to VCD but I have a movie that is not converting. It plays fine in Quicktime, but when I convert to VCD (using the preset) I get a failure error. The info says it cannot convert the audio track, so I'm using the Passthrough function for audio, but I've tried that before on a different file and it didn't work.
    Can anyone recommend a fix?
