How long would it take to rip a movie using DVDXCopy? 1hr? Any faster way like maybe DVD Shrink? Thanks for any help![]()
I think you just have to try. No one here can tell exactly how fast your system is using those tools.
Good Luck10110101100111012011 <- The bug Bill doesn't talk about. -
When you say "rip" do you mean just ripping or the whole process of duplication ?
I guess the bottleneck of the ripping process is DVD read speed and HD write speed in the second place). DVD Writers don't usually have a good performance ripping, you'd better get a dedicated DVD reader.
Well, if you want a figure with your burner I'd say between 20 and 30 minutes. You shold have DMA activated and a non very fragmented HD.
Upgrade Celeron 2.6 socket 478 & mobo
By kenmo in forum ComputerReplies: 2Last Post: 6th Jul 2010, 21:29 -
AMD Sempron Vs Celeron-M?
By Super Warrior in forum ComputerReplies: 8Last Post: 14th Sep 2007, 22:08
